enzo3856
- Reaction score
- 220
Question on idling and what effect a pipe has on it..
I had my CY26 in my Baja last year. Running a standard WT668 and dominator silenced pipe. Motor ran great, but I needed the idle screw turned in all the way or else it would not stay on.
This winter I moved the same motor into my DBXL. The only difference is the air filter (TGN easy clearance Baja filter, vs TGN short stack) and the pipe (silenced v2 dominator vs RCMK XCR pipe).
With the new setup it was idling way too high and I had to dial out the idle set screw almost the whole way out... I did not change anything else (needles are the same)
Just wondering why such a big difference? would the pipe affect the idle so much? or could it be atmospheric difference between summer and spring? just trying to understand...
otherwise, performance is not affected. Car is snappy and accelerates normally and strongly, no bogs.
