I have backups for my backups so bear with me.......
The manual and pictures I have seen show the arms looking really similar to each other. Both the top and bottom ones. If a person was in a pinch could you make the upper front arm work for the upper rear arm or vice versa?
Maybe the fronts would work on the back but the back not on the front kind of deal.
How about the lower arms? Front to back, back to front. No way in xxxx will either work. How about if McGuyver was there? McGuyver with a Dremmel?
I am just curious and thinking about ordering up some more items for spares/backups and if I can get away with a set of upper arms that would work until I order the correct set. I could then get back up diff pins also which is a different thread coming up.
