hamster huey
There are boat pipes on ebay for 23cc and up engines starting as low as $15! Silicone and hose clamps can be used for joints. Some come with a header and stingers/tubing. Hangers can be made from lots of stuff like coat hangers wrapped with fuel tubing or even muffler hangers from full sized cars or a thick metal rod. You can ask the seller about size before buying. The only questions I have is are they tuned for high, low, mid, or all around performace and how well will they work on MONSTER BIG TRUCK? I have an Xcan now but it seems to lack power compared to a tuned pipe. The reason I run a Xcan is because it is completely protected under the body. If boat pipes have good power they might be able to be mounted in an area that is protected or on the other hand certain ones are cheap to replace so it would not be that much of an issue if they took a few hits. What do you guys think?
