Innovative Rc differential case for Hpi baja .
Barber213
Good afternoon . I have a question . I recently purchased the innovative differential case for my baja 5b . I wanted to know if I’m suppose to use the two small o-rings . One on the outer and one the inner side of the case or just the outer sides ?
There's only a slot for an o-ring on the outer side of the case. You can use bearings or bushings supplied.
From the outside working in, it will go bushing/ oring/ bushing
