Stygian
Banned
Any recommendations for an aftermarket intake manifold for the MT as I read a thread that the stock one can warp.
I might just buy a new plastic one and paint it. When painting things you always have to primer it first right, I don't know much about painting.MrMeatHooks said:There may be custom colors available. I would use some High temp paint on the black one, be sure to get all of the oils off first using dawn soap or laquer, these work great on oil. If it will work on an oily V8, it should work on an RC car lol.
Good idea, but I'm too OCD/Anal and have to have the original ones that are made for it otherwise it will just piss me off knowing they aren't the ones made for it lol.Sergio said:I go to ace hardware store Just bring The carb and manifold so You can try them two washers and two lock washers
Oh ok im The same way but sometimes cant wait For The mailmanStygian said:Good idea, but I'm too OCD/Anal and have to have the original ones that are made for it otherwise it will just piss me off knowing they aren't the ones made for it lol.
The plastic intakes warp from heat causing air leaks and engine failure.don't purchase a plastic intake and paint it not worth the hassle.buy a good aluminum intake and get good gaskets.plastic is cooler for 1:1 automobile cold air intakes bc the air is not heated so quickly by the hotter metal tubes so ur forcing colder air to the motor.but on rc engines u wont notice the difference of a 1 inch plastic intake plus the high temps warp and cause severe tuning issues.ask any one that switched to a aluminum intake if they go back to a plastic one.i highly doubt it....just my 2 cents...MrMeatHooks said:Yes, looks like sandard flange for CY, HY and Zenoah Motors. I was thinking about an aluminum spacer, however I have used plastic/phenolic spacers on intake manifolds and the truth is, they are cooler. The point is to keep the carb as cool as possible, the cooler the carb stays, the denser the fuel charge. . Aluminum spacer heats up very quickly and transmits heat right into the carb bolted to it. I would say aluminum is more for looks, then performance
Yes they fit. These type of parts are universal.Stygian said:anyone know if this will fit the MT http://www.davesmotors.com/s.nl/it.A/id.4477/.f
