Is it worth going big bore or upgrading stock shocks
Big bores buddy!!! I ran mine today for first time and they are an awesomely smooth ride!!
Although I run mine on a heavy sandrail......black hd springs might be too much?
i don't no if the HD springs may be to much ive never owned any or seen em
in the flesh, so you think the springs will be overkill?
ive heard alot of probs with these shocks not fitting to well? its kinda puting me off
because i run the TR rear v2 brace and im getting the 5T TR combo brace for the front
and by looking and reading about them on forums you need to cut the shock braces just
so they can fit... :(
I know nothing about these particular shocks. Something to think about can you get parts for them? I run the stock shocks with the Threshold seals and have not had a problem. I do want to get some better shafts some day and the Threshold Rezzies.
From what little I know from reading the big bores are more necessary on heaver baja. I do all I can to keep mine as light as possible. At 25 1/2 pounds ready to run with out fuel is heaver then I would like.
