Here's the center ones
http://www.redcatracing.com/RC-Cars/Redcat-Parts/07126
and here's the ones that should have come stock, which you can flip 180 degrees depending on what you want.
http://www.redcatracing.com/RC-Cars/Redcat-Parts/07179
I run 3 degree rear in on most my RC's. T4 stadium truck and slash 4x4 included. I run my short course truck with front toe-out because the longest straight section is 8 feet. I'm pretty much constantly weaving in and out of hairpins, chicanes, ect.
The biggest effect toe has on the handling of the car is on stability. When a car hits a bump or enters a corner, forces on the tires act to steer the car off to one side, making the car unstable and difficult to control. Toe-in counteracts this, improving stability. Toe-in also causes understeer during initial corner entry. Interestingly, toe on the rear wheels has the same effect on handling as toe on the front. Toe on the rear wheels is useful for tuning the handling of the car as it is exiting corners.
Front Toe "IN"
Slower steering response
More straight-line stability
Too much will casuse greater wear at the outboard edges of the tires
Front Zero Toe
Medium steering response
Minimum power loss
Minimum tire wear
Front Toe "OUT"
Quicker steering response
Less straight-line stability
Too much will cause greater wear at the inboard edges of the tires
Less Rear Toe "IN"
Less traction out of the corner
More steering
Higher top speed
More Rear Toe "IN"
More traction out of the corner
Less steering
Less top speed
