nfaustdoty01
- Reaction score
- 0
Does the Jet Pro work with the 7075rc Rear Shock tower? I see many people run this pipe but all the pics always have stock cage mount for shocks.
That is what i was thinking. Looks like where the jet pro mounts is right in line of where the middle of the tower is. I like the stock mounting location, it is just a pain for removal. Guess when i get my pipe i will just keep the shock mounting stock. But i did really want rear sway bars.topblissgt said:I don't believe it does. Wish it did I would have it on my Sons Chimera
ooohh taking $$ from my wallet again!Ol said:I make one for the jet pro pipe, I have one on my Chimera. I have not put up pix on my site yet but it is the same price. If you want one just add a note.The top of the shocks sit inside the cage, leaving room for the jetpro above the cage. It is a cleaner look in my opinion. The only drawback is the spring adjustment ring hits the cage so you HAVE to run it down about 3/8th of an inch. You can make up for this with shock oil or differant springs. I have some pix on another computer that I will look for.
Sweet, that is perfect news. I will be ordering a gear plate in the next couple weeks so the tower mount will be bought then as well. That one also includes the sway bar kit?Ol said:I make one for the jet pro pipe, I have one on my Chimera. I have not put up pix on my site yet but it is the same price. If you want one just add a note.The top of the shocks sit inside the cage, leaving room for the jetpro above the cage. It is a cleaner look in my opinion. The only drawback is the spring adjustment ring hits the cage so you HAVE to run it down about 3/8th of an inch. You can make up for this with shock oil or differant springs. I have some pix on another computer that I will look for.
