John Blaze Chimera build
Almost forgot I'm also using 7075rc suspension bushings four in total on the rear a arms
In the shocks I put 40wt losi shock oil and the diffs I have 60000wt front and back the handling is much better now
John Blaze said:
Next I'm going to take it out for a nice bash session and break in these new tires shouldn't be a problem in the snow
Now that sounds like fun!
Lookin good...i like all the hop ups also like the butterfly knife. Is that in case some one interups ur build...lol...keep up the good work...
Lol thanks, I'm kind of a knife collecter I always seem to find a way to use them in my builds
just did the full read/and vids very nice, john. may get one, but my XB has been great .
the lighter units XB/chimera/XT are nimble and tough...DR is close second as well as losi sand rail ...oh choices.
nice detail , thanks
That is exactly how my diff cup looked when I broke it the carbon fiber has made my drive cups much stronger and I haven't broke anymore drive cups since.I got the carbon tube on ebay I believe it's 20mm ID just type carbon tube and diameter it should pop up I got the idea from a thread on this forum best mod you can do to your drive train the copper or steel tube would just add more rotational weight and is harder to install I just glued the carbon on with some thin high quality tire glue
Thanks for the update John
I will try the 22MM OD x 20MM ID X 500MM LONG Carbon fiber with 1.0mm thickness from ebay
Yes the measurements are right. Just make sure to lightly sand down the inside of the carbon and outside of diff cup before applying the glue.
