Just a thought, any other alternative kill switch available?
nolivy
Brandon Manitoba
Just a thought, are there any other kill switch available out there that works on channel 3? Just wondering whats the competition in this area?
I have a killer bee v1, works great, no complains about it.
Hi there.
1. Could you insert your Location in the UserCp section when you logon?
This could help others assist you as/when necessary from time to time.
2. Check out Ebay. Certainly on Ebay.co.uk there are a couple now, and Hobbythek are marketing their own I think.
There are various battle switches and modified pico switches available, the obvious and high quality Killer Bee and the new Switch Blade kill switch amongst the 1s already mentioned
i had a modified pico switch fail on me, after that i decided to go with the killer bee and its been in the car ever since without any issues.
Heard of a few pico's and battle switches failing so I went straight for the killer bee but then inherited a battle switch on another car I bought & its been ok up to now. Will prob change it out when I get some spare cash to be on the safe side.
how to view the pictures there? it says domain unregostered?
Any way, I have a question on killer rc forum, kent can you on it...it is about the voltmeter. Thanks.
Hi killer rc, how can I know what vesion of killer bee I have? I forgot which one I have, I had my second baja and I want to install another killer bee, I have flysky g3tb tx/rx set up.
Thanks. The killer bee I have works perfectly, can turn off engine thru channel 3 button.
I've never ran one in any of my LS's. As long as you have your batteries charge and plug right into you servos and receiver you're good to go.
I've been running gassers for over 8 years now before they made 1/5 offroads
If the Aux works then its a V1. See labels here. http://www.killerrc.com/products/gas_killswitch.php
^ Last words before a runaway. LOL.
Run your cars often enough and it'll happen. It happens to even the the pros. Nobody can predict a servo failure.
Boy you are super lucky wish I could say the same!!! but servos do go out still and the kill switch saves alot of pain weather it be your pain or someone else or property.
The last 4 years I've been running a Elcon cleon, if I feel a glitch or something strange I shut it down. The radio is set to brake and turn right. The last runaway I had was a nitro back in 2005 because of a wire getting stuck around the throttle linkage.
Lucky maybe yes but I'm more aware now running something so expensive!
