Just about time to order
KauseKaos
BKLYN, I'm Home...
Well its just about time to get my 5th. I'm going with the FG Monster Beetle Pro. Is there anything I should change off the back? If possibe can you put the part #s so i can find them. Thanks in advance.
Go to DDM's page (sponsers on the right of the main page ) and order their DDM Dominator pipe,thats your first thing.
J.
Well my suggestion is if you do not have a engine kill switch yet.....
you will need to get a picco modified kill switch......Plus I would do a engine screen mod
....Those 2 things are very important.....besides getting the tune pipe.....
Ok you can look in my thread..New to 1/5 scale slawhammer's project
Page 5 post 68.......That should give you a good idea
and an aluminum spur carrier. the plastic one will strip out. you'll need the 60mm one for 46-48 tooth spur. and aluminum upper rear arms will keep them from flexing and hitting the spur gear.
a better servo tray is nice but if you add a couple extra support posts the stock ones still work decent
yep Barry has it right with the support posts on the radio tray
you can just make out the alloy support under the brake/throttle servo
Changed plans. Found a used FG Monster Truck for a low price. Waiting for it to come. So once I get it I will post pics and take it from there.
