DemonRC1
1) The connectors look fine to me. Anybody have any problems with the stock connectors? I was wondering if I should stick with em or upgrade.
2) This might sound silly but I don't have an instruction manual explaining the charger/balancer. Is it a overnight charger that charges through the battery's balance plug? I just need it so I can run tommorrow at work. I'll have to head down to the LHS Saturday and build me a connector so I can charge on my real charger.
3) Did you guys get a manual on the operation of the ESC? I only got a parts manual.
4) The XBE backend is rock solid. I had a theory that all the rear diff case failures were due to rear end flex on the XB. Any of you XBE guys having rear diff failures?
