brio
Hi guys. Need some help. I just got an XT. I was doing the pre-run check and I can't get the plastic gearplate off. Not sure if that's the correct name for the part, but it's the plate where the tranny gears sit and it covers the clutch. I removed the 3 long bolts and the little screws for the cover. I then removed the last gear on the shaft that connects to the center pinion and pulled, pulled pulled, it rocks a little but not coming off. Like its seized on the bearing around the shaft that runs through the brake assembly. The plastic gear plate should just slide off, right? Any suggestions to remove it will be greatly appreciated. Thanks.
Reason for removal
. Wanted to check out clutch and possibly change spring to HPI 8k RPM. I heard so many good things about the HPI 8k spring so I figured I'd install it before the trucks maiden run.
Reason for removal
