dwarfy
Ive posted this in my re-build thread but will post it here for a wider audience.......
This is a pic of the air intake after removing the K&N filter from the marder I recently bought as a project. You can clearly see a lot of sand ingress so you can imagine what the internals will be like after that! The compression is poor and there are no prizes for guessing why!
I bought a new engine for it due to having the filter off & expecting the worst so fortunately don't have to worry about having a non-runner on my hands but any noobes beware of the risks!
If you are running a K&N make sure you have an oiled pre-filter & outerwares to protect your engine. My 1st marder came with the same filter but had only 2 tanks thru it and was still clean inside. Rather than change the full unit back to stock I bought an FG foam pre-filter (£3) and oiled correctly it works fine for me running at our site which is grass.
The TGN dual stage pre-filter is probably the best available for approx £10 and some use their wife's stockings (or their own maybe :lol
rather than the outerwares. Make sure you periodically clean them both and re-oil the pre-filter after cleaning. There are threads on here with tips on oiling.
The std FG and HPI filters are good and probably a safer bet for most, again used with a pre-filter or outerwares if conditions are likely to be bad.
Im sure there will be comments for and against and I am not saying don't use them just make sure you use them with caution!
