kill switch engaging again
jonathan13
Again I am facing a kill switch issue. I cannot figure out why it keeps shutting the truck down. I tried it at work and at home so I know nothing is interfering with the transmitter. My batteries are charged fully and I am running the recommended NGK plug now.
The last time I tried running it, it shut off within the first minute before I had even done any driving.
Any suggestions?
So unhook them and let it idle for a few minutes to test if it's going to engage the kill switch or unplug them for a few minutes and plug them back in without running it to sort of reset them?
Also try......
Turn on your electronics. Do not start the engine. Watch the switch to see if it ever triggers. If it does not trigger and only does while the engine is running, it is electrical interference.
Run the engine for 5 miinutes without servos to see if they are causing either a glitch or a battery spike.
It could be frayed wires or any number of things.
It could also be a bad kill switch. But 9 out of the 10 that were returned were good. 1 was obviously broken solder. Did you look at the kill switch with a magnifying glass.
I Will take a closer look at the kill switch today and also run without the servos plugged in. I don't understand what has changed because ever since I put that NGK plug in, I never had issues and now all of a sudden it has started happening again.
rampage hop ups is right, andy ken is also pointing you in the correct direction. may not have been the spark plug to begin with. could be just from working on the r-c, moving the wiring around. i suspect broken solder joint-s where the servo wires connect to the printed circut board- and-or- the same thing where the recievers antenna wires connect to the circut board. yes the antenna has 2 wires. its called a dipole antenna. look real close at the reciever- remove the 2 screws, cut the sticker with a knife, open it up and look.
posted this before. its r-c season. time to repost. the recievers antenna wire has a loose fitment where it goes tru the recievers case, this places all the stress on the 2 solder joints. split the case, look @ the 2 antenna wires real close. if they look good- put a dab of shoo-goo where the antenna goes tru the recievers case halves, and reassemble.
/monthly_2013_03/583c60703b949_ARROWSSHOWGLUEPOINTS001.jpg.159b7effeae93593d37ddffd1c64b365.jpg
/monthly_2014_03/583c60703d031_ARROWSSHOWGLUEPOINTS002.jpg.6e68f91e724524b69e98db4674b37aa6.jpg
Well I just tried running it with the servos unplugged. I didn't think about it before but with the servos unplugged the kill switch stays engaged so I can't do it like that. Am I missing something with that plan?
I'm thinking the servos being unplugged shouldn't engage the kill switch.
I'm with Alfred, I think it's an intermittent transmission to and/or from rc/tx.
As always.... I reserve the right to be wrong.
With the servos unplugged when I turn on the receiver after it initializes the LED immediately goes red. I just tore the cover off the engine to check the connections at the "stop button" and everything is fine there. Put it back together, started it and it ran for 45 seconds and then the kill switch engaged again shutting it off. I've checked the solder on the kill switch and wiggled all the wires from the servos, battery, on/off switch, antenna, and tossed my remote around a little and I can't get it to replicate it turning off. I'm clueless once again
Since it does engage with the servos unplugged does that mean there is something wrong with the kill switch?
Is the green LED on the kill switch supposed to stay on all the time? It has always blinked when first turning on and then went out, but now that I am looking at it closer sometimes the light goes solid green and sometimes it starts flashing green again and then as I said before most of the time it stays off after I turn the truck on and it has initialized.
Okay so I just left the truck and transmitter on WITHOUT the engine running and the kill switch engaged and went red. So it doesn't have anything to do with the truck running. If that is the case what does that point towards?
Reset the kill switch and this time it stayed green for 2 minutes and then the light went off, but it hasn't engaged and went red yet
Edit: engaged and went red again while left alone with engine not running.
It should not make any diff if the servos are not in circut. the kill switch should operate corectly. i think the problem is electricly speaking-- up stream some where in the wiring. but-- i could be wrong. just saying.
