killer b
andyken
New Hampshire
My stock radio works fine engine off...but with the killer b and engine running the throttle servo twitches?
Unplug the killer and servo is fine.
I moved the killer away from the receiver as far as I could in the batt box and it helped.
Seems like the wire to kill switch on the killer b is causing interference?
A new spark plug, and use an EMI filter on the gray cable, which come on the newer Super Bee kits.
It has that on it, I got the rec in front right of battery box, and killer in the rear left...still makes the throttle twitch a bit.
I was thinking of extending the wire and mounting the killer to the rear of the roll cage in a baggy?
Did you try a new plug? Also if you take a look at Killer RCs site you can install those filters on the servo wires.
