Killer Bee Grey Wire
Dreggsta
Baton Rouge, LA
how did y'all run this wire? i was thinking of drilling a hole thru the top plate that the plug wire is ran thru. i was going to see if there is a grommet that'll fit the grey wire & the hole nice & tight first tho. how did y'all do it?
also, i remember some of y'all saying ya'll removed the coil. the instructions even said it too. why? to connect the stop switch to the coil? i didn't have to remove the coil. i just plugged the killer bee stop switch w/the coil attached.
thanks in advance guys.
I was able to run the wire behind the cover underneeth the carb. I'll take some pics tomarrow if you want em
all right, disregard. i started looking at the plug wire grommet & noticed redcat was nice enough to have a 2nd hole in the grommet along side the plug wire. it's its own hole, 2 seperate holes. so i ran the killer bee grey wire through it. :)
thanks motakitty. :)
i have a 2nd question now tho. how do i set the 2 switches? aux/glitch kill or no aux/glitch kill? i am using the stock tx/rx. thanks again in advance.
It should work when you turn the radio off it should kill the engine but I'm still new at this so maybe someone else will chime in
I don't think it will work on that third channel because the radio is only a 2 channel transmitter.
I have mine set to the no aux kill setting and I have it plugged into the 3rd channel. It kills the engine when I shut off my transmitter.
ok thank you very very much fellas. heeheehee, now i have another question, lmao. i have a voltwatch2 that i bought to help monitor battery level. it has a j plug (i think that's what it's called that plugs into the rx channel ports. correct me if i'm wrong.) & my rx doesn't have a 4th channel port. so how should i wire this thing? i take it i'll have to get a y plug but how would i wire it? y plug the steering servo like the killer bee instructions say or yp lug the killer bee & voltwatch2 together? help please! i'm at a conundrum!
