Stygian
Banned
What are the recommend settings for the dip switches on the killer bee kill switch?
Put it up on something so the tires don't touch, and test it. That's what I did.Stygian said:ok I have both switches up since the receiver has an aux channel I hope that's the correct setting lol
the stop button works but i'm not sure if anything else works, how do you recommend testing it, if it's going and I shut off the transmitter it should kill the engine right?REVOlutionary Rampage said:Put it up on something so the tires don't touch, and test it. That's what I did.
Like I said, put your truck up on a block or milk crate etc...so that the tires are up off the ground THEN test it. Start it etc... and like rookie said, The on off switch on your radio should shut down the engine if everything is plugged up right. Read the directions they tell you exactly how to wire it or just check out the link I showed you.Stygian said:the stop button works but i'm not sure if anything else works, how do you recommend testing it, if it's going and I shut off the transmitter it should kill the engine right?
