Just make sure the gears are seated properly. Some have had gears that don't sit flush on the squares.rampagemt said:I will stick with plastic and drill them. I never really messed wth the gear plate or the gears on it for my pre rtr plan. Do I need to do anything to the gears under the cover or the shafts before i start it up
To be honest, I don't know if Redcat carries the aluminum holders, anymore. I know TheNitroRcShop carries them but from what I've read, you do need different pins for that setup.caveman said:Thanks deluge going to upgrade to aluminum when I can, in the meantime ill drill the plastic ones and anchor em down. Now with the aluminum upgrade do I need different pins?
