Killer switch question.
Do you mean that it doesn't kill the engine?
Got the t-shirt on that one!!
Simple recommendation from Killer B themselves was to try another 'R' (resistor) rated spark plug, then it cut perfectly again!!
I tried it close by, cold, warm, very hot, as far as I dared - no problem!!
Now cuts 1st time every time as before.
Check the radio set binding is correct, try another plug, and see how you get on.
I'am on my 3rd killerbee v#1 they did not last long.. and scott from nutech racing, has a pile of them,..after this one goes I'am getting the PICO switch.. I think the relays in these are way to small.. JMO here..
Never had a problem with any of my Killer Bee kill switches. I did replace the first one that never gave me a problem ONLY because it did not have previsions for a external light to tell me when the kill switch is on or off. Was working fine when I installed the up dated model. If I am not mistaken the Killer Bee is nothing but a modified PICO. Correct me if I am wrong.
Hi guys, i have the killer bee v1 kit 3 as pictured here
http://www.mmrlargescale.co.uk/shop/...ler_bee_kit_1/
and it works when i flick the aux on the tx all fine and dandy but not if it looses signal (ie i turn the tx off - all that happens is the fail safe kicks in)
Any help?
Cheers guys
What radio do you have? I'd guess that its a Spektrum. Your radios built in failsafe is overriding the kill switch. This is easy to fix. Just hold the Aux button in the off position while you rebind the rx and tx. That should fix it.
Any time you have a problem all you have to do is email me. I'll get ya taken care of. [email protected]
We use the exact same relay as the Pico. You either have real bad luck or a bad installation. Email me and we'll get it figured out, or fixed, or I'll give you a refund.
I got one in my fg Baja , hpi Baja no prob both are running spectrum dx3.0 no prob killer rc top shop good serviceeeeeeeeeeeeeeeeeeee
Not only does Kent make a top notch products but he all so has excellent customer service!!!!!!!!! I will run nothing but a Killer Bee remote switch.
Your a star, problem has been fixed thanks to killerc :D
When having a problem with any product best thing to do is get in touch with the guy that distributes or sells them. I have been dealing with Kent at Killer RC for about 3 years and has always gone out of his way to help. A+++++ products and customer service!!!!!!!!!!
