king motor 3.0 2 speed alloy F003 radio help
rshaff
fort worth,texas
when i sqeeuze the throttle trigger it brakes.i'm not use to this.how do i reverse the throttle.the cd it came with wont read in english.i don't want to use a different radio because i like that i can turn the lights on with the km radio.thanks
Mine came the same way. You have to go through the menu and reverse the throttle. I don't have my controller in front of me right now. But I will in about 2 hours. But it is explained in engrish on page 17 of the PDF.
says something bout pressing the select button to access several functions one of which is REV. you select that, and if i remember right theres a check box or selection to reverse the 2 servos, you just have to select the th/brk one not the ST one,
ok ill try it when i get home thanks.do you know where i can buy an extra battery pack my hobby store don't carry king motor prouducts and i cant find it online.thanks for all your help
Your hobby store likely carries HPI products. So ask for a high mAh 5 cell 6 volt hump battery that fits an "HPI Baja 5B"
