KM Baja 2.0 EX teardown and slow build (pic heavy)
monster1-4
MA US
Just want to create a thread for for my teardown and slow build. Here we go!
So far the person that put it together at the factory was a loctite happy guy! No complaints but it's a pain to take out those screws. I striped one of the four screws that holds the engine to the chassis! Need to take care of that before the engine can be removed.
I only use loctite on engine bolts, carb and exhaust header only because I like to sevice and rebuild my regularly
Troy
1 top tip, do the pinion bolt/clutch bell mod....you swap the standard pinion bolt with a slighly longer bolt and install from inside the bell then add a couple of locking nuts to the outside, this helps to get the pinion bolt out if it snaps...
Thanks for the tip! I'll make sure it's done! Any other tip?
Short shorty baja?
These look cool aswell and its a direct fit over the 5B and 5T
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.10434/.f
Troy
Thanks! They do look cool!
Been very busy with work. Had a break over the weekend and took the baja apart and then new idea: short short baja.
I understand that in this configuration the gas tank is out of the equation. But if I modify the chassis (actually thinking of making a wider one on my own I can hopefully fit a different smaller tank (may be side mounted). The question is which tank.
Any suggestions?
