KM Baja 5B
ajdenning22
Yukon, Oklahoma
so im thinking about making my 5b to a 5sc i have found a 5sc conversion but don't know if i have to make it a 5t first or can i just do the 5sc conversion.
different bodies, but also different front and rear bumpers,, 5sc don't have front lights,, like the 5t,, and the 5sc has mudflaps in the back,,, 5t don't,,, different tread tires,,, otherwise should be the same, both bodies would work with either set up
The kit should come with everything you need to make it a 5sc. Check to see if the kit you are looking at comes with the body mounts and hardware first. Also compare the kit to pictures of a 5sc with the body off to match up the parts.
