Kraken RC Maxxis Trepadors Tires
William E Burrows Jr
Florida
Dear WoodiE,
I run on grass tracks so larger tires makes sense.
To run these tires I had to rebuild the transmission with DDM Mega Torque Gear Set KV103, install a 2nd Steering Servo Bracket Kit KV2240 and a Kraken TS-555HV Servo KV3323. Total cost with tires and inserts $404.00.
I hope all this is worth it.
Best Regards,
William E. Burrows Jr.
Dear Evssv,
I saw a video running the Mega Torque Gear Set, thats how it started.
I knew I would gain much better low end and thought I would lose a little high end.
So I changed the gearing.
At the time I was unaware that I would be loosing almost 50% of the high end.
To make up for the high end loss I needed the larger tires.
I failed to due my home work on this conversion.
Best Regards,
seems a bit extreme jus to run different tyres dude:unsure:
