Large Scale bearing dimensions
Stegy
Zagreb, Croatia
Hi,
I'm trying to find some bearing dimensions of few large scale manufacturers/models.
So, if you have one of these cars and know exact bearing dimensions used, please write them here.
I have all dimensions for FG and RS5, but I need from:
1. H.A.R.M. - SX3/BX2....etc.
2. Lauterbacher SuperSprint, SuperCross, Megacross...
3. Genius - ....
4. Carson...
5. MCD all models...
6. HPI Baja 5B...
7. Some other you have/or know exact dimensions.
Please write them like this for example:
RS5 F1 new type:
1. 8x22x7 - 8 pcs - wheels
2. 10x22x6 - 2 pcs - clutch bell
3. 10x19x7 - 2 pcs - central shaft
4. 5x11x4 - 4 pcs - pushrod bellcrank
5. 10x22x6 flange - 4pcs - central gears
6. 15x24x7 - 2pcs - differential
P.S. Admin could make this topic sticky, it's good to know what bearings you need, what dimensions and quantity. :idea:
FG Modellsport
1. FG Marder, Marder Race, Monster Truck, Stadium Truck, Jeep, Hummer, Baja 2WD
1. 8x22x7 - 8pcs - uprights
2. 10x22x6 - 2pcs - clutch
3. 10x19x7 - 2pcs - central shaft
4. 12x28x8 - 2pcs - differential (plastic housing)
2. FG Leopard, Competition Monster/Stadium Truck
4. 15x28x7 - 2pcs - differential (alloy housing)
3. FG Sportsline
4. FG Competition, EVO 04-08
5. 7x11x3 - 1pcs - alloy servo-saver
6. 7x14x5 - 2pcs - alloy servo-saver
5. FG F1 Sportsline
2. 8x16x5 - 2pcs - clutch
4. 15x28x7 - 2pcs - differential alloy housing
6. FG F1 Competition (belt drive)
7. 7x11x3 - 8pcs - pushrod rocker
8. 8x16x5 - 4pcs - rear belt tensioner
9. 8x22x7 - 3pcs - front belt tensioner
7. FG F1 Competition 08-09 (gear drive)
5. 8x16x5 - 4pcs - central gears 38 teeth
6. 7x11x3 - 1pcs - alloy servo-saver
7. 7x14x5 - 2pcs - alloy servo-saver
8. 7x11x3 - 8pcs - pushrod rocker
RS5 Modelsport
1. RS5 Formula 1 (old type central gears with e-clip)
2. 8x16x5 - 4pcs - central gears 33teeth with e-clip
3. 10x22x6 - 2pcs - clutch
4. 10x19x7 - 2pcs - central shaft
5. 15x24x7 - 2pcs - differential
6. 5x11x4 - 4pcs - pushrod rocker
2. RS5 Formula 1(new type gears with locknut)
2. 10x22x6 with flange - 4pcs - central gears with locknut (outer diameter of flange 25mm, flange thickness 1.5mm)
3. RS5 TC CR-008
1. 8x22x7 - 6pcs - uprights
2. 17x26x5 - 2pcs - rear uprights inner bearing
H.A.R.M. Racing
1. HARM TC SX-3
1. 8x16x5 - 8pcs - uprights
Lauterbacher Modelltechnik
1. Lauterbacher TC Super Sprint
2. 10x22x6 - 4pcs - clutch and central shaft
3. 15x28x7 - 2pcs - differential
