Layshaft bearing question
maddmike
I got my mt gear plate for my xt and the bearing I got was 1mm thinner what size shins would I need to take out the extra slack ? Please post link if you can
I just ran into this they are 8mm shims I did not have any I can tell you that the lock nuts that hold your 4 gears on to the shafts the washers behind the nuts are 8mmx 1.5mm if that is too much I comprimised I took a teflon washer and sanded down to 1mm or you could try loosening both lock screws on that layshaft and see if you can get enough movement to take up the play I almost got it by doing that, I called fastenal I deal with them all the time and he could not even find me 8mm shims maybe someone else on here knows, good luck I had a female dog trying to get it perfect
