ldleing Issue
BIG Oz
Junior Member
VA
Having an idleing issue now after i got it broken in. It start up will not stay running. I have to set the ldle hight, or keep giving it gas. How can I set the idle or how can I tell it right.
Sorry new to 1/5 scale what is that and how do that, once I open the gas cap it has pressure.
try adjusting the low speed needle. Probably try leaning it out a little (1/8 turn at a time) and see if the idle speeds up. If so, keep leaning the low speed and turning out the idle until idle is smooth and the engine is responsive from the line.
There should not be pressure or vacuum in the tank. If you hear the hiss when you open the cap you need to vent the tank.
Cool I try it this tomorrow. I did have a gas under the carb, I cleaned the filter and checked the carb dolts, and re tight theme.
There is pressure in the tank. I do hear the hiss when you open the cap. Now how do I vent the tank?
