leaking oil
James1996
I Have a redcat rampage mt that leaks oil from the heads of bolts that holds the muffler. I have replaced the gasket and I am using a ratio of 25:1. and running out of solutions can anyone help
Try some high temp RTV on the exhaust gasket. Apply a light layer on both sides and let it sit for a few minutes, then install it and you should be good to go.
