lean fuil suplly
max 1
i can,t get motor ricther have the hneedl out 2 turns plug still gray.new motor carb ,i was thinking the clunk may be pluged .no air leeks any wear.any ideas stump.
have you richened the low end? your pick up in the tank my not be down in the tank deep enough or has been switched around
the low end wont afect the high end ,and the fuil filter is right under the drive shaft in the tank cant move at all,
no air leaks .the screan in carb was dirty,now i cot some color on plug.being that lean that thing was sceaming like a banchee, new something was wrong.
if the carb screen was dirty, I would also change the clunk in the tank. in a pinch you can go to the local pet store and get a fish aquarium airator stone. they work good as clunks and filter some crap out. just rinse it out good with gas to remove the loose stuff before dumping in the tank
filling in the hole on back side of 813 carb .thotle shaft allaso made big difference in tuning.
