Legit cab popoff gauge.
Trung Phan
Hello all friends. I want to buy a carburetor popoff pressure test, I'm watching over YouTube how to do the test, they also give a advice buy a Mikuni one. However when I search on the Amazon, ebay most of comments said it not a legit Mikuni one. Can you help me which website I can find a legit Mikuni popoff pressure gauge.
Thanks for your time.
i got a knock of one, works fine
if the gauge is a little out, u can take the backing plate of and with fine nose needle pliers, adjust the dial back to 0
i got one from ali express and it works fine
17psi to 20 is what you want
with the metering lever = if its a tad high, will flood and or overfuel
if its set a tad too low will lean out
