Leopard Motor and 7075rc Motor Mount on XBE
XBENOOB
Hanover Ontario, Canada
Here's what my XB-E (aka XT-E) looks like under the hood...
  • Leopard 5692 (8mm shaft)
  • 7075rc Motor Mount
  • HobbyWing EZRun 150amp ESC
  • 48 tooth Spur
  • 10 tooth Pinion
  • Aluminum front and rear side links
  • Aluminum A-Arms
  • Aluminum Top Plate
  • Aluminum rear Wing stay
  • 7075rc Rear Bearing holders
  • 7075rc Front Bearing holders
  • Aluminum front and rear shock towers
  • Proline bow-tie's on desperato rims
  • ramtech hpi adapters (I have the 7075rc ones, but they need to have a few thousands shaved off for them to work)
  • killerrc light kit with 4 front light pods and rear tail lights and blue underglow
The only thing that is still non-replaced original parts are:
  • front and rear diffs
  • the chassis
  • rear bumper
NICE! What KV 5692 did you go with and how did it compare to stock?
I picked up the 1340kv which has been running pretty dam fast. I'll post some pics later with my setup which is close to yours.
DemonRC said:
NICE! What KV 5692 did you go with and how did it compare to stock?I picked up the 1340kv which has been running pretty dam fast. I'll post some pics later with my setup which is close to yours.
I also picked up the 1340kv with the 8mm shaft from offshoreelectrics.com
http://www.offshoreelectrics.com/proddetail.php?prod=leo-5692&cat=148
It's very fast on 6s. I picked up a mamba xl so I could run 8s through it, but it was recalled. I sent it back on Sept 1, 2011 and Castle is shipping it back now. Should be in on Wednesday.... (today)
Once I get it, I may change up the spur and pinion. Maybe go to a 41 Tooth spur and a 16 Tooth pinion. That should make it fly on the straights....
Man mine was pretty dam fast on 11/48. I can't imagine 16/41. No doubt the motor can push it but do you think there will be any heat issues? Let me know how that goes. I'm interested in hitting light speed too :) .
God, I can't wait to get my parts and then get it all installed together, Gonna be a fun lil toy!!!!
11/48 here too on a leopard 1340kv!
