Largescalebuilder
Reading the Rules!
The problem is the oil mix. I had the same problem and kept adjusting the oil mix untill the problem went away. Now I run 50:1 mix. The problem is that your fouling out the plug with 25;1 mix. It's ok to break it in but you will have nothing but problems later. Also check for air leaks a rebuild carb kit will also fix the problem to. If you see lots of oil comming out of the exhaust when running then you know that it's too much oil.
