loads of smoke and oil from exaust
MARLEY76
sheffield. united kingdom
hi im pretty new to 1/5th rc trouble im having is my 26cc cy engine wont tune up . theres loads of smoke as tho its rich as hell. even tho L/H needles are just over 1 full turn . doesn't sound well either .theres lots of black oil from exaust had newish ngk plug fitted too. thinking its the head gone but just wanted to ask you guys first..also i have to keep reving it slightly to keep it running .. any info really appreciated..thanks lads..............
What mixture fuel / oil ratio are you using. Most use 25:1.
If your mix is old, I'd probably consider ditching it and making fresh.
A full (very simple and LOADS of videos) tune up would help as well.
r8 atom3624 thanks for your quick response much sppreciated .. im using 25:1 oil mix .using putoline oil. but ill do a fresh mix and see if that helps .. also gona go more leaner on lowspeed needle.. thanks for your reply atom3624
What carb do you have on it?
hi phill2... its a walbro 216 it says on it .theres no other markings on it ..I've just done a fresh mix of fuel and gona see how it behaves .. I'll post my results later on ..and thanks for a reply m8
results are in lol.. its running the same as before. ive noticed a slight air leak on exaust manifold even tho its just had 2 new gaskets on .. and the gasket seal between engine and cylinder head. seams to be tacky like as tho fuels melted it if you know wot i mean.. it all worked fine untill i had to change the is it pinion gear and the rear diff. had some spares. so put that on... also ive fitted a fg fuel tank with new lines fitted .cleaned and checked the small pin hole breather. on the cap too.since fitting these parts its just run poop and loads of smoke & oil coming out of exaust pipe. so ive decided to take engine out and strip it put new gaskets and maybe a new piston kit...and new plug . if i renew the piston only. do i have to run the engine in like you do on new ones. thanks .........
the gaskets mainly the cylinder part was wet through and degrading also insulater gasket was wet too.. piston looks fine all shiny ect cylinder same ..just thought i would let u know ...
thats a good one phill2 . i think new gaskets n carb gaskets should do it. i hope lol.. as it starts up ok and ran fine before. well fingers crossed it all works fine after doing new gaskets. thanks for your replies mate .
