dwarfy
- Rossendale
Yes Ive been on here ages but what exactly is a long rod engine :innocent:
Your welcomecheers bud that helps out loads :cool2:
my new motor is a 2mm long rod with a 29cc head and stuffed crank weights it takes the cc up to 30.5 by using a 1mm copper gasket. i,ve only run it for half a tank but it runs well and has got mega grunt low down.
squish is fine and the motor runs spot on .
Sounds good Pab. Get some vids posted :cool2:
I have a guy out here in MI,build my motors,he also builds some of the fastest boat motors,he mainly just does local stuff some out of state,but has another job building test parts for either Chrysler or GM,so dosent devote all his time to building these motors,but i have ran my motors agianst oniel bros motors,and after seeing the diffrence i wouldnt have anyone else build me a motor,i do no my stuff about motors,i was rebuilding motors when i was 15,but when it comes to porting on the 2 strokes i would rather have someone who has a lot of expierence,and lathe and the other proper tools for releiving pistons,and top of cylinders,to get maximum preformance out of them.whittron who built your long rod motor or did you build it?
