More people seem not to have the problem than do have it. I think what overheated mine is the combo: holding wot over 10 seconds+flooring everytime time to accelerate+thick terrain+huge field+90-110 degree sunny day+ported engine w/power adders+low to mid speed gearing+4wd+sucking air at the bottom of the tank when fuel sloshes+non releived piston+stock needle settings, etc. I think that combo of driving it like it was stolen on a very hopped engine on a hot day along with heavy 4wd was just too much without steps for proper cooling.
I think of it like this: a engine can be driven driven hard shortly but if you want to drive it hard long you have to take the proper precautions. A engine all hopped up with a pipe, carbs, filter, stack, flywheel, porting, cylinder bore, stroked stuffer crank, turbo, etc, etc. is operating closer to its limits so it has less tolerance for abuse and is closer to failure.
That is why I have taken engine friendly precautions: gearing that achieves speed w/o WOT, running 1 hour richer, making the Ramp 25lbs, refilling at 1/4 tank, not holding WOT for long, relieving the piston, in addtion to: running 25:1, keeping the HPI filter clean, keeping the cooling vents unobstructed. Im sure you can think of more.
Thats what Ive done so far to prevent my “overheat rpm seize” but even if you disagree it still doesn’t hurt to be kind to you engine.
