Long travel suspension
Spoogity Woogums
I'm looking at some extended arm suspension sets for 300$, and I'm here again bugging you all to see if there are shock towers that let me mount the upper shocks at a lower point than stock. Some of these extended arm sets have the towers, but is there a way to buy JUST the towers?
FLM has these mounts you are looking for. I have the 2 different front and rear FLM mounts that I should sell as these didn’t fit with the use of TC cage and Rezzies. If I remember I’ll post the pics.
I found the mounts I can buy separately, but the rear doesn't look like it lowers much from where stock sits
Take into consideration, the lower you put your shock on the control arm. there is more of an angle with the drive shaft and cups, which will cause stress and you destroy axel boots
I had rezzies and FLM extended arems on my 5T and I can tell you they are the best investment I have bought ( apart from a killswitch of course)
