Losi LST wheel nut removal
i have one completed i had a solid aluminum bar to make the insert piece but i would of preferred aluminum tube that is OD 8mm & ID 5mm.
it was dumb from losi in 2004 to put a 24mm hub on a 6mm shaft that's why it got changed later for the lst2.
even Kyosho was smart back in 2002 with the mad force it has a 14mm hex with the pin through it with a 19mm hex adapter that sits over it.
He's talking about the shock mount screws in reply to me.
yep i didn't see the quote lol.
i just found out about the traxxas revo 17mm hubs with the screw pin that are nearly a direct fit i have some and used a 5.5 mm drill bit with my hand and spun some aluminum off and now it's fits perfect i should not off bothered making that one insert piece at least i didn't make 4 of them.
