Losi releasing a Losi 5ive-T Roller
WoodiE
Kind of good admin.
Community Leader
Kentucky
Losi just announced they will be releasing a pre-built roller version of the Losi 5ive-T. Just add electronics and engine!
Bigger. Faster. Stronger. Customizable. The 1/5-scale Losi 5IVE-T 4WD Off-Road Racing Truck Roller is the closest thing to a full-size vehicle in realism, performance, experience and customization. This version of the 5IVE-T includes all the components that have made the 5IVE-T iconic with the exception of electronics and an engine. This is the ideal vehicle for drivers who prefer to choose their own destiny by choosing their own engine, servos, and radio equipment.
Features:
  • 4-Wheel Drive Power Train with All Metal Gears
  • 5mm Aluminum Chassis Design Based on Successful 8IGHT™ Platform
  • 3-Tunable Sealed Viscous Differentials
  • Large-bore Shocks with 7mm Shafts/Threaded Adjusters
  • Multi-Piece Beadlock Off-Road Wheels
  • Aluminum Dual-Disk Braking System
  • Extra-Large 800cc Fuel Tank With Clunk
  • 2-Stage Air and Fuel Filter Systems
  • Full Roll Cage Modeled After Full-Scale Trucks
  • 4-Piece Body with Ability to Replace Individual Panels
  • CV Driveshafts Used Throughout
  • Innovative sealed clutch mount with cooling fins
Needed to Complete:
  • 2.4GHz DSM surface transmitter and receiver
  • Gasoline with 2-cycle oil
  • 23–29cc Gas Engine
  • Tuned Pipe
  • 1/5-Scale Steering Servo
  • 1/5-Scale Throttle Servo
  • Polycarbonate Paint
  • Receiver Battery and Charger
LOSB0024 - $1,099.99
1,099.99 USD = 724.640 GBP
Losi 5IVE-T 1/5 4WD Off-Road Truck (Black/Bind-N-Drive)
(LOSB0019BLKBD)
£949.00.....In J.ER Models (roughly same as everywhere I have found)
So for £225.00 your getting elec's plus engine.Is it worth buying a roller or a BND??
J
:rolleyes:
Is that front driveshaft really at that weird angle?
Doesn't it create cup wear problems?
Don't like that!!
Al.
It does cause wear but not that bad - 30 tanks thru with chain lube and cup reversed once . Not bad even when you have to replace the cup at 10$ per piece every 20 hours of use.
