98NYFinestVette
- Old Bridge New Jersey
How are the factory servos? Has anyone had to replace them? I know the HPI 5SC are junk, wondering if the LOSI followed in there foot steps.
Having had a close look at the Losi servo and the Savox servo - it's the same servo - the other day I was told that a Losi customer in the US recieved a replacment Losi servo that turned up as a Losi product but in a Savox box.
We had one of each open at the last meeting and other than the case colour & label, they were identical.
ya thelosi and savox are the same,savox makes two diffrent servos thats probally why when you looked you seen the diffrent specs,probally looking at the other savox servo,but i am running stock losi servos with 7.4lippo since i have had my car and no problems probally have 15 tanks through her,good luck..
I don't know if you guys are having the same problems as the racers over here but a lot of the racers are having issues with the steering loosing power half way through a 30 minute final - there are a lot of different battery/transmitter set ups but they're all struggling with it.
I had to replace the throttle/brake servo about 2 minutes after turning the power on. Not happy
lets just get something straight. Servo horn's were off prior to powering up. Battery Pack used was the pack supplied. After a 1/2 tank run the steering servo is on it's was out as well, and that was not hard driving l was just running the engine in. IMO l would put it down to poor quality servo's supplied by LosiAny ideas why?
Sounds strange, unless it was seriously not set-up correctly - servo horn not correct - and the servo strained.
Did you connect LiPo 2S and the servo's not compatible?
