Lost Hardware Need Help
vince1
Junior Member
I have lost the bearing, spacer, and screw needed to hold the steering knuckle and c-hub together. Must had came loose on one of my runs. The parts are for my XB-E and ordered from 7075rc. I had check their website but there's no option to order spare hardware. Any help is great. Thanks all!!!
no separate parts for those
sounds like a trip to the hardware store for screw, always buy stainless steel
the bearing from VXB.com.
the bushing, buy caster/spindle set (plastic) set from redcat dealer, or make your own.
OL fart sells set of 4 spacers And if you email him, he might have bearings...
Fast eddy also sells quality bearings for $1-2 ea.
Don't ALWAYS buy stainless steel!!! It is brittle....should only be used where shear strength is not needed.
Stainless is fine when threading into plastic, not so much for aluminum. I learned the hard way, I've had screw heads shear right off when used with aluminum.
Also, just a heads up when looking for bearings, check out Avid RC. I got a complete bearing kit for my 5T for $26. TFE and LSRC wanted around $40. Can't beat that.
If you want to DIY the screw is a M5x12 ButtenHead. The bearing is a M14x4x7. The sleeve will be the tough part but you may find something at the hardware store you could Mod.
