Lost screw on Hitec 645. :(
vpalace
PA
Hello again all, was just out bashing and when I was packing up, the screw for my t/b servo fell out and is now lost forever.
It's a Hitec 645, can someone tell me where to get another screw or what size I will need?
Also, can I use a little bit of loctite on that small screw?
Thanks again!
I will check it out. Does anyone know if the stock screw will work in the meantime?
I have order before but can't find them now so i emailed asking for the part number. I believe the sizes are 2.2 mm and 2.5 mm i think the one you need is 2.5 mm, but not positive.
Awesome, thank you! Can i use a touch of loctite so this doesn't happen again?
