Lost steering
edl
Round Rock Tx.
Hi guys I was running my MT everything going great, I drove up to the garage let idle ready to turn it off and discovered my steering quit, I have a Futaba 4PLS I noticed when I hit the throttle the bars moved on the display when I turned the steering wheel no bars on display, batteries are charged,I re-binded the radio still nothing when I used the steering trim it did move the wheels but the steering on the remote does nothing. thanks for the help.
Hmmmmn. That's a tough one. Never had that happen. You can try to plug your steering into the throttle channel to test the servos beings you said the throttle channel works. Otherwise I have no clue why that would happen. Maybe loose rx plug connection?
I had a similar problem that had me scratching my head.
Turned out the rubber on the "steering wheel" had come unstuck.
Bit of super glue fixed it.
I think a got it fixed, somehow the D/R Alt went to zero on the steering, the button is on the top right side of the grip handle it is possible I could have done it and realized it. thanks all again, Great forum!
