Everything is U.S. shipping only! I will combine shipping costs. Paypal or Postal Money Order only. Please PM me with questions! Thanks.
If in Canada, PM an address and I'll determine shipping. Thanks!
Differential Gears 48 teeth
$12 shipped
1 new out of package
1 used
14 and 16 tooth steel layshaft gears, brand new
Package was cut with an intent to install it, but I decided I didn’t want to tear into the Firehammer at the time.
$12 shipped
Lauterbacher 19t Pinion Gear for FG’s. #80093D
Brand new, package opened. I was told it would work for Firehammers. It doesn’t. FG only. Steel-Gear, 19 teeth For FG/Harm, suitable with plastic-gear w. 46 teeth.
$12 shipped
Clutch Bell
$8 shipped, good condition
Brake kit:
New Brake Cam
New Disk Brake Set
New Caliper Set
$5 shipped
Dogbones and Axle Outdrives:
Used condition, 2 dogbones, 2 axle outdrives, and one diff outdrive (not pictured).
$15 shipped
Steel long drive block
New, Hobbypro packaged, no set screws.
$7 shipped
Steel short drive block
New, HobbyPro packaged, no set screws.
$7 shipped
Used Drive Blocks
Long and short, great condition, no set screws included.
$10 shipped.
2 New Packages Steering knuckles & 1 Package of new Rear hubs
$8 shipped
Used Firehammer MT Body
A few cracks, still in good condition.
$25, $10 shipping.
Used Firehammer Tires/Wheels ***SOLD***
Still have good tread. No cracks on wheels. Dirty, but good for some bashing.
$25, $10 shipping
FG8484 Alloy Diff housing with Firehammer/Firehammer MT gears! ***SOLD***
Excellent condition. Gears are smooth, bearings smooth.
Will be shipped with two horribly worn outdrives for keeping the gears in place in the housing.
$70 shipped.
Alloy Motor Mounts ***SOLD***
Used large mount (Firehammer MT only) and used small mount (Firehammer MT only).
I had to tap the 4mm to a 5mm hole for the bulkhead brace. Works fine though. I’ve also made it where you tighten down a nut to keep the screw from backing out where the bulkhead brace mounts.
$35 shipped
Alloy Rear Hubs ***SOLD***
Great condition! A couple small nicks, nothing bad.
$30 shipped
Alloy Steering Knuckles ***SOLD!!***
Great condition.
$50 shipped
17 tooth steel pinion gear (Firehammer and Firehammer MT only) ***SOLD***
$15 shipped
19 tooth steel pinion gear (Firehammer and Firehammer MT only) ***SOLD***
Steel 48 tooth spur gear. ***SOLD***
Still in great condition. No messed up or worn out teeth.
FG 6439 Alloy Gear Carrier 60mm, brand new. ***SOLD***
Works with Firehammer spur gears.
$12 shipped
1 used
$12 shipped
$12 shipped
Clutch Bell
Brake kit:
New Brake Cam
New Disk Brake Set
New Caliper Set
$5 shipped
$15 shipped
$7 shipped
$7 shipped
Used Drive Blocks
$10 shipped.
$8 shipped
$25, $10 shipping.
$25, $10 shipping
$70 shipped.
$35 shipped
$30 shipped
Great condition.
$50 shipped
$15 shipped
