Lsn and idle gap, fine tuning for bottom to mid range
Houser1995
Hello all i haven’t been messing with my gassers for awhile now since my Baja 5t gave a small tree a little head on kiss and completely blew the front bulkhead and surrounding parts to pieces.
But I recently broke my feet in a motorcycle accident and been off work so I’ve been using my time to get the Baja back up and running along with a rampage Xr (rally) that I bought cheap last year.
Anyways enough blabbering and onto the real question, ive got the rampage Xr up and running now after putting on a new walbro 997. Which ironically is all that it needed! I’ve got it tuned and running good! It will drift around on pavement and it has no trouble screaming and getting on the pipe. But I know that there is surely more bottom end torque and response to be had at the low end.
So what do you guys do to fine tune the low speed for 0-1/3 throttle? As of now my idle is set about 1/2-3/4 up the tip of the idle screw which I feel is probably a bit much. But when I back off the idle and lean the low speed some I feel as though I’m losing some torque. Also the motor is 4 stroking under no-light load and up to about 1/3 throttle.
The difference is honestly very minimal so I wouldn’t say I have an issue. All of the threads on the various forums and the DDM instructions don’t reallyI just would like to know what you all do to dial in the low speed settings!
Oh I also found a thread/guide on a rc gas airplane forum that did mention tuning the low speed by holding the throttle about 1/3 open and adjusting the low speed screw until you hear the engine smooth out (stop missing/4 stroking) under no load. Anyone ever heard of this?
You cannot go off airplane settings, whole different ball game.... tune by ear and tune by plug appearance. You tune the low end first then worry about the high speed needle 2nd. I will turn each needle till I hear an audible change in sound as it bogs its too rich and if it breaks up or lacks power it's too lean up high. There's no science and everyone will tell you something different as everyone's ideal tuned engine will be slightly different or others may have the money to rebuild engines to have an edge as lean is mean but not safe. Each engine will have its own sweet spot and final tune and that's for how the engine is wearing in and how you treat it.
