h11nta
Reading the Rules!
Hi All
Does anyone know were i can get two magura master cylinders from the ones that pull out.
Does anyone know were i can get two magura master cylinders - Rossendale models for any magura spares
from the ones that pull out. ???? Do you mean the old type Magura Mk1 master cylinders?
please see photo attached
You have IMO one of the best braking systems available but I need to see photos of the hubs with the calipers mounted AND the servo set ups. I would'nt go back to the old ones for anything.
First thing to do is check the operation i.e take the caliper off the hub and see if the piston is moving when you operate the lever.
Then check for leaks, then blockages, if all is fine check all your bleed nipples haven't been over tightened as this will damage the internals of the master cylinder and the nipple (they did change them at some point for an idiot proof version)
It looks like you're using the Lauterbacher brake fluid, no matter what anyone else says, use the right stuff, hobbytek is probably the best place to get it from.
If all else fails but things seem like they should be ok, then strip the system down and put a seal kit in.
Mike
p.s I could really know what is wrong rather than "i can't get them to work."
