Marder Shock help
sidewayzbaja
Miami
Well today i was looking at my marder and i saw that my rear shock's don't oil in them. So i want to know what weight should i use??? For drag racing
and when it squats you will see the tires lean in and less contact patch on the ground. you want to limit your travel with the screws in the arms. if you are drag racing you don't need much suspension at all. so get it low and stiff. add shock spacers if you have to to get the springs stiff, use the screws in arms to limit the travel. you don't even need more than a half inch of travel, and then set your camber and toe in
I gotta add there are guys that know a lot more about drag racing around here, I am just remembering stuff they said in threads. the ney york crew of guys have a really strong drag background...
hey big brother, where ya at man, this is your realm to add some info
