mcd samba pipe
thanks mike ,how do you get the old ones out, and where do you get new ones from ..............phil
the pipe just pushes in ,they must be some ring in there ,i have seen some exhaust with rubber sleeves over the joint ,maybe that could help.............Phil
there are 'o' rings in there that break down over time, you just flick them out with a thin screw driver and replace with the new ones. Phone rossendale models and get them to send you some.
I have ran a good few Samba's and if the problem persists with new rings the pipe has gone out of round at the joint.
You can use heat wrap on the manifold too!
J
