mega quarter bracket
According to the specs, you should be able to bolt it up directly to the HPI bracket without the adapter.
HS-805 Mega 1/4 Scale Servo Specifications:
Bearing Type: Dual Ball Bearing
Torque @ 4.8v: 280oz\in (19.8kg\cm)
Torque @ 6.0v: 320oz\in (24.7g\cm)
Speed @ 60 degrees @ 4.8v: 0.19
Speed @ 60 degrees @ 6.0v: 0.15
Standard Size L x W x H: 2.6" x 1.2" x 2.3" (66mm x 30mm x 58mm)
Weight: 4.2 oz (152 g)
