mesh mod question
maddmike
Ok guys I pulled my flywheel off for my new one and while I am at it i wanna do the mesh mod to the case from the inside. what should I use for the mesh any specific Kind? And what sort adhesive would be the best? Shoe Goo is what I was thinking but maybe epoxy well enlighten me and my lack of knowledge please.
One more question? What would a good torque wrench for the job be that's inexpensive thanks
I think the shoe goo would not stand up to the heat. Epoxy sounds too permanent. It would be a pain to get off if you ever had to replace the mesh. Maybe high temp silicone? Im sure others will chime in.
Yes i seen your screen it post. I am wanting crankcase mesh not full out body mesh plus its goin on dune runner I think that would Look strange. So no go on shoe Goo then shucks
Deluge said:
You can use aluminum window screen. I've seen guys use JB Weld, Shoe Goo and silicone. They all hold up pretty well.
Deluge said:
Clean the surface with some alcohol, as well. If it's dirty, nothing will stick to it.
+1
I use aluminum screen and Permatex Ultra Black on all of my motors and it's held up perfect for years now. :)
