metric or American bolts?
Neff
Chassis, receiver box etc... the allen wrenches supplied suck, is everybody using the T handled?
Metric?... I don't have any specs on bolts. Would it be a good idea to buy a complete bolt set for my XT as spares?
All the hardware is metric. I use hex driver bits with a mini cordless driver for almost everything.
RCDAD.... Any idea if I can get a random charger for my transmitter at a local store anywhere. not sure which one it takes and the right fitting any help on that so I don't have to remove the batteries every time to charge it
You should be able to find one. I save those wall chargers when the device goes bad. I was able to find one in my box.
The Radio does not regulate the charge. I use a 12v so it is impossible to overcharge the AAs. If you have a higher volt wall charger you will have to monitor the charge time. When looking for one you want it to be in the 12-14v range. The plug is + inside and - outside. (+)-
